Has anyone compared the performance difference between the Valve Index and their pimax?
Can anyone who has both compare the performance of the two? Let’s say you put both on 90 hz, and 200% steamvr SS. Would the index reproject less due to rendering less pixels? And if yes, is it a small or big difference in performance? I also heard that the index has its own “parallel projections” setting and its automatically turned on. So best to also turn on parallel projections for the pimax and compare the two
I’m sure @SweViver will cover this in his Index review (I hope!)
Indeed would be good to compare. Though if your looking to compare performance on even ground. Pimax should be compared on Small FoV. As Index does not have the additional scenary to render.
