Half Life Alyx Vr , Pimax results and troubleshooting
Same here, wanted to check this thread to see if others were getting this.
I also had some bullet holes on the wall not rendering in both eyes. The blood texture has been the worst though, headache inducing.
Smooth turning works fine for me.
Didn’t see a setting for smooth turning. ?
It allows you to change it when you start, but you can access the options from your non-dominant hand.
Thx will check again when back in.
Sorry @dogbite, I misread @jTeller post.
are you using index controllers?..I accessed menu from non dominant hand and turned off snap turning and using “continuous motion” by head movement and still snap turns…aaarrg.
Are you saying smooth turning is not an option?
When you mentioned “needs smooth turning” after @jTeller menitioned it isn’t working, I thought you were referring to it not being available as I didn’t change it from the default.
is smooth turning working for you or not lol
I was. I just missed the setting I guess. Will look harder when back in. THX
What catalyst setting are you all using? I have no clue what it’s supposed to be set on. I have a 11gb 2080ti and it’s saying low gpu memory at the start of the game menu. Anyone else getting this?
get the latest driver, I have a 2080 and no issues…running at ultra and 120fps. Only problem graphically is culling/glitching on the right side whether PP is on or off for me.
What fov? 20char20char
I call it texture clipping. It does seem reduced a lot ,if I don’t launch Pitool, but is still there a little in some areas.
PS your right about quick turning. Stays on even when deselected.
ah ok, I’ll try without pitool. Also, do you in fact have smooth turning working like @g-coded mentioned?
I updated my graphics drivers and it seems to run great now on Ultra. I was able to get rid of the flickering by turning on PP, then resetting the Pimax service, and then rebooting the Pimax HMD. After that the flickering is gone and the game is running perfect. I have Hidden Area mask on, PP on, catalyst set to 0, Smart Smoothing off, and Fix Foveated set to close (off).
will try this :+1:
do you have smooth turning working?
No quick turning (incremental) stays on, even when turned off.
