luce
#1
Can we have some word on the status of this bug?
Having to fiddle with the work around to get normal performance is a serious damper on the experience.
It was documented as repeatable across multiple systems over 2 months ago
Pimax please is this being worked on?
The research of Northeastern University has mentioned the problem of GPU bugs and optimization. The Challenges of Writing Portable, Correct and High Performance Libraries for Gpus Or How to Avoid the Heroics of GPU Programming - DocsBay
It seems in the second half of this article. Hopefully it helps.
