I have that one - but do not use cable extensions - just an optical cable.
Thatās the one Iām using, with extensions as mentioned above.
yes i have that one,i dont use any cable extension.i am using still the orginal cable by the wayā¦
I dont have optical cable. Maybe thatās why my expirence so far is not perfect with this firmware
I know but right now Iām not sure if I want to invest that munch in extensions againā¦ Waiting for official build and will decide later.
the alpha firmware work perfectly with my rtx3090 in 90hz and the new nvidia driver 471.11
great pimax
Is this alpha firmware working with RTX 2000 cards ??
2080Tis and Titan Xps have reportedly had 90Hz working even on 298, but needed old drivers. 3090s had the same problem on 298 tho, so 100% 2080Tis and Titan Xps will have 90Hz working on 471.11 driver now. They havent behaved differently than the 3000s, so why should they now
17 testers from here on openmr have the alpha firmware in the last 2 weeks, 5 of them have the latest build. 6 testers here also have the DMAS. On the firmware we are now down to 0 people who have issues with it. Probably wonāt be long now before we move it to an open beta.
Eureka ! Itās working now Flashed alpha firmware once again but this time Iāve changed DP connection between HMD and my new RTX 3080ti Palit GameRock Oc card. Apparently, in my GFX card DP nr. 3 has the strongest signal becouse now itās working with Club3d 8k60hz 2m extension cable. No issues like before - sparks and blinking . This firmware is great. Whatās an amazing HMD ! Kudos to the Pimax dev team !
Ahemā¦
After some years i finally got myself a 8k-X
Can i test the alpha firmware too please ?
I would like to test the alpha too.
Can anyone please confirm the number/code of the alpha ?
Maybe iām already on it without knowing, as i have the option but it donāt work.
the alpha is only open to a select few members (17 i mean) who report to pimax on it.
Correct - if you request it, theyll give it to you but you need to give feedback to them
I donāt know if thereās other versions as well (in circulation) but Iāve tested this and it works with nvidia 2xxx series 90hz:
P2_RELEASE_8KX_M298_t20210528185255_r1cb2901.dfu
I have a RTX 2080 (not Ti), Do you know if this beta firmware works with this GPU ???
