Hello Looking at pimax just for a virtual cinema(no gaming at all). Was wondering what version hdmi or type of other port do I need to enjoy the full resolution experience also can I just use a 4k ready n.u.c mini computer connected to the pimax h4k headset for watching movies? thanks for your time Bluc…
Hi PiMax 4k will definitely work great 4 movies.
PiMax 4k uses HDMI v 1.4b
Pimax supports 2k directly, the Pimax will up convert to 4k res using interpolation(sp?)
Which is what any display will upconvert or down convert to displays Native resolution.
If you have to wear reading glasses, you will be dissappointed and Pimax will be out of focus.
