hi
-yes and no yes it should work but the usb2 will limit performance.(some guys use a USB3 cable in addition)
-i don’t no. if there are space betwen lenses maybe.
-i think yes it is clip on lense, so when you move IPD the eye tracking move with lense
I didn’t mean about the usb cable but about the face interface. I’ve read some people had to cut off the plastic to fit their ET. Is it necessary, do I have to order a vision comfort kit (I’d rather not) or can we install ET without moding the old face interface?
