I’ve grown tired of Bethesda’s old titles and IPs.
" You can only drive down main street so many times"
Only now I understand that doom vfr can work with only small fov, not more, else graphics bad !
Well, that would not be the first game that gets blurry on bigger fov and/or resolution. I remember same with i.E. “Robinsons: The Journey”
Guys I figured something with this game; it has adaptive resolution, some parts of game are in higher resolution, and some are in lower. Unfortunately they made mistake, and clearest part is not in the sweetspots, but more to the outer edges.
It is visible if you watch any detail with one eye, and turn your head left-right.
This is mirror from right eye, large fov:
I was playing this game on small fov, and then probably I got highest resolution almost in sweetspot.
So many bad reviews, and disappointed people, just for that…
PS: Also minor error is with HUD, it is better to disable it.
