I thought I read that it came with the enhanced audio when I bought it, but I just wanted to make sure because I haven’t heard anything about the enhanced audio solution and the current one on the mas is very bad from what we’ve heard.
Are You asking as a backer or someone who pre-ordered it on the website?
If it’s the latter it depends on what You ordered.
You can see both versions here:
https://store.pimaxvr.com/shop/product/modular-audio-head-strap-311
As a backer upgrading
In that case, I’m not sure (I’m not a backer), but what I am sure about is that it’s been discussed several times so I’m sure someone else will chime in…
Then You should be good for the deluxe audio strap I linked to.
They’re the ones that haven’t been showcased yet and which should be using one of the “big guys” drivers (JBL, AKG etc.) according to @SweViver (not his exact words, but something along those lines) …
