I bought it 2 years ago. It doesn’t display the version number in the floating window. Steam website doesn’t show any update option. If I begin the buy process it just tells me I already have it.
Right-click it in your Steam library listing, and open the properties window, then check in the Updates section. “Always keep up to date” is usually the default updating option.
It’s set to always update. Thanks for the quick response
