b) I get obvious distortions on the side with Large FOV, at normal FOV I have to look for them and try to notice them, on small FOV I don’t have any.
c) I only see what I’d call blurring on large FOV and if I try to focus on the far sides.
d) Doctor office measured IPD of 61.5, but I set every headset (not just Pimax) to 64 and learned that before I got my Pimax even. I am suspect of the doctors office measurements and I will be asking them to be extra precise on my next eye examination.
e) Not sure, I don’t feel I have abnormally deep eye sockets or anything.
f) I am using a leather padding that I picked up off of Amazon that was meant for a Vive, the stock Pimax padding worked fine for me but I wanted something that was more easily wipe downable.
g) Yes.
h) I use a DAS, which I think makes all fitment issues very different than the strap. No one with a Pimax should settle for a strap.
8K with standard foam.
IPD set at about the middle. I wind the adjuster all the way in, or out and it makes no difference.
No noticable distortion anywhere.
