Sometimes it is a little bit difficult to find important information in this forum
So a try to find out this way!
Are there binding informations when the delivery of the 8k + should take place or when the orderer will be informed by a delivery date?
A second thing. The kickstarters will get their headstrap sometimes.
The 8k + only has the deluxe headstrap without speakers, right?
When will we receive the kickstarter headstrap with the speakers?
No, the 8k+ has the MAS (modular audio strap) with basic speakers. These speakers are open to the air similar to what has been done with the Oculus Rift and Quest. There is also a deluxe MAS that has speakers that extend down over your ear.
Just to note, the default speakers in the Modular Audio Strap aren’t similar to the Oculus Rift or Quest at all. Those things have small speakers within the headset that pushes the sound out along the strap, while the Modular Audio Strap has decent-sized speakers sitting on it near your years. Looks more like the Valve Index speakers than the crappy Quest/Rift S speakers.
Where did you read that? The only “ears on” I’ve seen is from SweViver, who said it had good sound quality, I’ve heard nothing about interference with the microphone.
In any case, my point was someone said it was the same as the crappy Oculus Quest / Rift S speakers, when it’s nothing like those.
