It’s been said before, but the lack of installation directions is a bit annoying. I wish there was a wiki, but can we at least get a sticky thread to combine the various installation instructions? Here’s a start of one below, but first a question
How do you install the Eye Tracker /w the Comfort Kit in the Backer Box? Do I seriously need to cut a whole into the just delivered comfort kit to accommodate this? I could understand if a cut was necessary for the original gasket, but it makes absolutely no sense for this to be needed with the just shipped kits. Though perhaps that helps explain the lack of official instructions…
References:
- Backer Box Installation Guide
- Eye Tracking
- https://community.openmr.ai/t/usb-3-0-eye-tracking-module-setup/30514. (references a ‘detailed’ instruction coming soon)
- Is the Pimax Eye Tracking Module Worth It? My Review and Installation - YouTube
- Hand Tracking
Tips I’ve found so far:
- When installing the comfort kit
- to remove the cowling, start at the top center and work your way around. It does take some effort to pop free, and one of those plastic wedge tools may help once you get it started.
- to remove the side hooks that held the original cloth mask, simply push them flat and they slide right off
