Hello again,
as i wrote in my last post i turned the resolutuion of the 4k to 1080p to see if it changes anything for my blurry Image. Now when i try to set it back, pitool just freezes. I tried to uninstall and reinstall several times, but its all the same. I can’t even adjust ipd or anything else, without causing pitool to freeze.
The overlay of pitool is kind of transparent now in dark areas. I’ll attach some screenshots.
Hope anyone has a solution for me😔
*Edit
I figured out that pitool didn’t freeze at all, just the popup menu is invisible… Altleast i’m able to change settings again🎉
