CAN Pimax 8k work on a laptop with MINI display port?
Will there be an adapter for mini display port on a laptop?
Yes the v2 was running mini dp to hdmi adapters.
You might need a mini 2 full size adapter depending on what is in the kit. With adapter an active might be better then a passive one.
I see. Thanks. I will look into that. By the way @heliosurge, have you heard of the issue with htc vive not working when connected to gtx 1070 displayport? Do you know if it Has been fixed yet?
Yes i posted a link awhile back as some founder editions cards are also affected
http://community.openmr.ai/t/pimax-4k-is-my-screen-broken/2241/18?u=heliosurge
