Bright vertical stripes
Hello,
I own a Pimax 4K for about 1 year. Now I have one bright stripe on the left eye - see the picture.
I have rollback to almost older Firmware an older Piplay with all checkboxes (on/off) … proofen.
NOTHING better.
Have anyone an Idea or solution to my fault?
Thanx
Frank
@PIMAX-Support
I have added at pimax supporr to assist support finding your post.
I don’t have a solution off hand but seems to be following the one set of defogger/demister lines.
Do you get this in games?
Also can you post your system specs with gpu driver, piplay version, first 3 serial numbers of headset & firmware version.
Hello Heliosurge,
Yes, this bright line is at every Game.
GPU Nvidia: latest 22.21.13.8541 (ForceWare 385.41) WHQL / WIN 10 64
Graphic Card: GIGABYTE GTX 1080 XTREME Gaming
Piplay: from 0.94 to 2.02 (latest)
Firmware: form 1.0.0.230 to latest
Serial: 100xxxxxxx
I hope there is a solution. In game its horror!
Is there a “hardreset”? - Also: i never opend the HMD!
Frank
Tbh to me might be a hardware issue. So will need support unless some1 else has had acsimilar issue & resolved it
Note:
I did experience those lines randomly in the 1st Unit. In the 2nd unit I didn’t notice it really.
1st unit was new batch, 2nd unit is old batch. Both were 100xxx serial.
I had exactly the same problem but in the right eye. Solution: you have to take out the filters (2). Be really carefully with it.
So remove the shudder glass. I would wait on support before takiung drastic measures.
It sounds like the shudderglass/defogger is failiing.
I will wait for the support.
Hi, I think @grzvs may be right but I don’t suggest that disassemble it manually.
Please contact that vendor directly as per her policy, meanwhile, I will also assist you about this case.
And please send email to support@pimaxvr.com if you have any doubt.
Hi PIMAX-Support,
the Problem is that I bought the HMD by gearbest.com and I live in Germany.
Now I have an paperweight? So gaming with that bright line is not comfortable.
Is there an Debug-Mode to solve this?
Hey bro, it is a Hardware problem not Software.
Unfortunately as @grzvs said this definitely looks to be hardware & not software. I am confident support will be able assist. Should be on in a few hours time.
Thanks @Heliosurge @grzvs
Hi @thx-ii , you may try to flash the firmware as per this link:
http://community.openmr.ai/t/release-pimax-4k-firmware/20
If it still does not work, please make a ticket to GearBest, sorry for inconvenience. :slight_smile:
Hi,
yesterday I removed the shutter glasses. And first wow … an absolut bright and clear picture. BUT now the latece from the Display is horrible! With PiPlay 2.0.3.xx there is no debug Menu to reduce the brightness of the display. So I wait for an new PiPlay or an FW with better low brightness.
So now I will try the old Piplay 1.1.92.
Thanx
Frank
PS: the price of return the hmd to gearbest is to high! So I test the 4K and wait for the 8K !!!
@Sjef has a modified firmware for 1.1.92 that has a lower setting.
hello Heliosurge,
thanks for the Info. Now I have actuell FW with Piplay 1.1.92 and it worked OK for me.
I only play ED, so the blur effect is not to bad for me …
I will go on with that.
Thanks a lot.
Frank
Your welcome. Though the credit for xtra lower brightness belongs to @Sjef. :v::wink::+1::sparkles:
