Blue line all over the sphere in steam games
Hi there! In steam vr apps I got a blue line all over the sphere. Anybody had this problem? And second question: how can I play not-vr games in 3d stereo mode in pimax?
  1. not sure
  2. use bigscreen beta and tridef3d.
Hello,
what version of piplay do u use ?
on my piplay version the 1.2.57 i have to add application in piplay :
and now u game is lunched on piplay :
For the blue lien i don’t see, can u make an screenshoot ?
have fun
Let’s talk here → Pimax 4K UHD - NON Officiel
youtube Channel → Issa pimax - YouTube
Twitter → https://twitter.com/pimax4kuhdfr
Now I’m at 1.1.92, but at 1.2.57 it was the same. like this.
It may take place at the equator or above / below
i don’t have it, u have it in all u games ?
or just this game, what is it ?
youtube Channel → https://www.youtube.com/channel/UCXfuq-tqCApmsx9qEBsvzzg
It’s the SteamVR chaperone. Just run room setup again, and it will reset down to the floor. Certain games make it change position, usually Oculus games and revive, for me.
Hi Rad, it looked like that images over the range of SteamVR room. Have you run Room Setup of SteamVR?
Did this issue only occur in SteamVR?
Please let me know what’s going on? Thanks @jonnypanic @pimax_fr
Thanks. Yes, I ran room setup. After several resetting it has gone down. What is this for? For not crashing my room and not getting hurt?)) They think I can get so carried away and forget where I am? Phhh. The only game I managed to see in VR was Deus Ex demo. That’s All. I downloaded RaceRoom Racing Experience and WarThunder from steam, added -openvr option but it doesn’t run in VR. I tried some games from torrents, fulfilling all the requirements for launching. And none of them had run. Open local doesn’t work nether.
Run the regular games through tridef did not work too. Runs only on the monitor screen. But Bigscreen Beta and Cmoar VR Cinema works fine so i can see at least movies
Hello,
if the problem is solved can u add [SOLVED] on the title
thanks
