Beta Pimax Server brings Netflix/Amazon to lag
As long the Beta Pimax Server runs, Netflix/Amazon Prime lags in 2 sec distances…
for better showing… when i quit the Pimax Software everything runs normal.
had the same problem a while ago with running some games while watching netflix or amazon with IE… change to morzilla helps me… was something the games uses or dont use right… couldn’t never figure out what the reason was… …do you changed browser for test?
of course…not :wink: this should be bug report, that the new runtime influences things that shouldn´t touched by the Pimax Software. hmm, maybe we need better Tags or a Subforum for Beta testing.
Indeed, would be good to have this kind of information (and interim workarounds, here the use of another browser) gathered and presented in a structured way so people can find it. A dedicated thread w/o discussion, a FAQ or comparable.
And before people complain why you would need to run the Pimax server and Netflix at the same time - just fly to Hutton Orbital for once, you‘ll learn how valuable it can be to enable watching Netflix as inflight entertainment… :smile:
For the mug!:coffee:
