This is a good topic and everyone is trying out various things that we can learn from and apply. What is unfortunate is everyone here reading this seems capable of making these adjustments where as probably the average user or new user cannot and that is the point of my earlier topic. For a test try reverting your settings back to normal what SteamVr suggests and what first time user will experience when starting their HMD. Its is horrible you will certainly agree if you test this for your self. These are a list of settings I have made to get a reasonably good experience playing Fallout 4 VR. Without these settings or something similiar I feel my Pimax 8k would be worthless.
Here are my current settings for Fallout4VR that seem to work well
Considering my game is fully loaded with 112 active mods and 87 active plugins
Tons of trees and an additional grass mod that I doubled the recommended load.
Sharp image and acceptable performance.
Change the following default.vrsettings at your own risk if your a Fallout 4 VR fan and want to experiment some. They may be reset anyway even though set to read only.
default.vrsettings
changed to read only
ârenderTargetMultiplierâ: 1.0,
âmaxRecommendedResolutionâ: 9000,
âsupersampleScaleâ: 0.039999999105930328,
âallowSupersampleFilteringâ: false,
âsupersampleManualOverrideâ: true,
âmotionSmoothingâ: false,
PiTool
Compatible with parallel projections ON
FOV Large
Refresh Rate 80 Hz
Render Quality 2
SteamVR Settings
Applications
Custom Resolutions
Fallout 4 VR
Big Edit: necessary after discovering motion smoothing was reset to true requiring the need for the 500% setting to get any decent visuals
After changing motion smoothing to false I am now able to get a much sharper image at only
200% or4520x 2208
Forget this 500% 7152 x 3492
Video
Disabled custom resolution
unchecked if you use it the Custom resolution you set
in Custom Resolutions will be overwriten so far for the
Pimax 8K running Fallout 4 VR 4520 x 2208 gives a reasonable
level of sharpness and performance using my 1080ti
Nvidia Control Panel 3D Settings
Anistropic filtering 16x
Prefer maximum performance
Shader Cache ON
Texture filtering Quality High quality
Vertical sync Off
Virutal Reality pre-rendered frames 1
Fallout 4 ingame settings
World scale adjustment MAX
Use Open VR advanced settings to adjust player height in game.
Disable CL, FXAA and TAA this alone will do wonders for Fallout 4VR
SteamVRâs recommended settings are laughable and an insult to the Pimax 8K
