Best Budget Laptop to run pimax game smoothly?
Hi,
What is the Best Budget Laptop MODEL to run pimax games smoothly ?
Is there any budget laptop with a 1080ti for exemple ?? or we don’t need it, we can go with lower ?
Thanks
See Sweviver’s topic. You need 1080TI at least, better to have 2080TI or even better 3080TI but that will take 1, 2, 3, (?) years. I wouldn’t call that a ‘budget laptop’ btw.
Agreed with SJ. A 1080 laptop might ne okay depending on what you want to run.
When available maybe a laptop with a 2080 might be good.
Otherwise a laptop with a graphics Amplifier would be best.
