Audio Hack and disclaimer edit for those who are may be considering
I thought this important for anyone who may be considering the audio hack i’m using on my Pimax Vision 8kX and read my earlier post.
[quote=“Fresco, post:1, topic:29099”]
edit: just to add a disclaimer here, if you yourself attempt this somewhat easy mod be aware of what i see as the only real danger is that you could do one or two things. The mod is so far dependent on one very small screw size ph000 and if you loose it well have to find a new one, or if you strip it out you run the risk of permanently damaging your smas and the option to for adding the later KDmas. Maybe someone could find another more secure way without damaging the smas. The screw can also easily come loose over time, so again be aware and perform at your own risk.
Fresco
