Everything works fine.
but. In the right eye my screen is divided in half horizontally.
The screen is duplicated on top and the screen is duplicated from the bottom.
In the left eye everything is fine.
Is there a solution?
Hi, please let me know what’s the Piplay version you used. Is it possible to take a photo of this issue?
Did it occur also in Pimax logo background when the headset was connected?
Please add our skype: support@pimaxvr.com to communicate, thanks.
I’m using Piplay 1.2.57
Such problems only in Assetto Korsa.
In other applications everything is fine
Thanks for your reply. Please let me know your PC configuration, we will use approximate running environment to test it.
Hi friend, you’d better add our skype for quick response
Did not solve the problem? (((
Hi, have you tested Piplay1.2.74_Beta version?
Please use debug_tool of Piplay setting to “export logs” to support@pimaxvr.com, thanks very much.
close topic.
The problem is solved.
But how & when?
It’s always good to post an follow -up resolution.
reinstall the game )))
