Honesty always survive. Thanks for the update. It was clear to me that as organization Pimax needs to be more professional to be able to handle this enormous project. I believe that the technical issues can be solved, although it can take a bit longer then expected, which imo is okay.
I can imaging the situation you are in: a fast growing company, hiring new people, instructing them, developing a challenging product, answering all your backers, being creative all the time, roadshows…when do you sleep?
The reason I was thinking about cancelling my pledge was only for the reason that I had the feeling that Pimax was over his head with this project. But if the organization will be up to the tasks ( and I notice you are working on that) then Pimax will have a major role in the VR world.
As a simracer on PC, VR was the big game changer with the Oculus Rift. Having more FOV, no SDE and higher resolution is very welcome as next step.
Although I do have doubts if my brand new GTX 1080+ will handle the resolution i.c.w. 80-90Hz. With the Oculus and an SS of 1.8 and low/medium game settings (acceptable image) I really need ASW for getting 45 FPS to 90 FPS and would need Brainwarp to do such a trick as well.
My question: do we need as much SS for the 8k as for the Oculus Rift CV1 to have a good image or is it not needed as the rendering to the HMS is already much higher?
