Pls share your experience!
That setup above looks good, what are you using for the headtracking?
I managed to get it working using the pingpong ball method and psmove service, but for me it was very delicate. One thing wrong and I would have to set the whole thing up again. And something would go wrong pretty much every time I restarted it.
Without headtracking psmove worked well, so hoping the Kinect 360 + driver4VR will be a more friendly headtracking method.
pingpong ball
I use a ball with ping pong.
There, the main thing is to correctly calibrate everything so that Psmove does not accidentally grab balls of other colors.
And for me the main thing is not to calibrate the controllers with the help of start + select.
