Adding headsets to pledge
Does anyone know if I got an early bird headset, if I can add more to my pledge at the early bird price to get another headset? Also, is there a limit to the number that can be added that way? @anon23564932, @Pimax-Support, @Matthew.Xu
Early bird would be just one slot, if you wanted another, you’d have to wait for one to open up.
Yes,you can add corresponding amount that is equal to an anther available headset plus same shipping fee to your current amount. We will send a survey to you through Kickstarter platform to gather your order details soon.
Is there a limit on the number I can add? How much do I need to add for shipping if I added 5, for example?
Yes, you need to add the same shipping fee more.
So I backed Early Bird 8KX does that mean if I add an 8K to my order I can have it for Early bird price? $449 and free shipping? @anon23564932, @Pimax-Support, @Matthew.Xu
Pimax-Support said
“equal to an anther available headset to your current amount”
I take that to mean only if an early bird special is AVAILABLE.
Yes, Free shipping for 8KX backer, if you want keep 8K, you need to increase $499 to your pledge.
@evertec asked:
@Pimax-Support said:
Yes, you can add corresponding amount that is equal to an anther available headset to your current amount.
I understood and I think evetec did too that we could get more headsets added to our order at the Early Bird price. So is that incorrect?
I wanted to know if I could add an Early Bird 8k for ($449) because I’m a Early Bird 8kX backer? I’m sorry but I just want to make sure we are all understanding each other.
I asked the same question earlier but I didn’t really get an answer. What if at the time of ordering there were 2 available early bird packages, so you increase your pledge based on the idea of ordering 2 early bird packages. Now, in the interim someone else has come and claimed one of the remaining early bird packages. Will there be a problem for us after the survey comes out? Will we be told “sorry, that is sold out”?
May this will make backer to misunderstand, I see someone ask in the kickstarter, and have to add by full price, not early bird price.
If we can do that, I can pledge more at early bird price for my all friend and this is not fair because infact it has limit quanity.
Yes, you are right, sorry for my bad expression. :blush:
Understood, thank you! :wink:
