Please, someone could answer me accurately, what is the minimum height that the base stations need to be placed so that tracking room works perfectly. I think I read somewhere that it would be necessary to be just above your head. Is that correct? If I leave 15 cm above the height of my head, it will work perfectly. thank you in advance
@Matthew.Xu @deletedpimaxrep1
You can put it on the ground, but you need to let it found you.
Now I’m in doubt if you’re kidding or serious. Is it even possible to leave them on the pure ground? Will they work?
Since the base stations like valves/vive there are many guides & likely youtube videos.
so you could kindly point me to one, where is it clear how much height is needed for the base stations?
Thanks…now i see it!!!
Yeah kinda annoying steam links sometimes don’t show
