I followed NextGenVR’s YouTube setup guide for installing the new Firmware Beta including the adjustable backlight option. So I launched the DFU.exe in …/Pimax/Runtime, clicked on the update file, and waited for it to be installed. When the update was at 98%, it got stuck. Now I am in DFU-mode limbo with the LED constantly flashing Red/Green/Blue and the headset not being detected by my system.
The part where I blame NextGenVR is his recommendation to unplug the Display-Port cable before/while doing the update. His answer to another user, who also is facing the same problem as me, was, that he himself actually didn’t unplug the Display Port cable when he did the update (and it went smooth for him)
How do I get rid of the DFU mode? How can I reset the 8KX? Any idea?
Putting in a ticket with support would be a good idea while you are trying to trouble shoot it yourself. A user in the other thread reported the below
Kudos to Pimax support for the speed of response to the ticket. I am really impressed. They sent me a P2_129 firmware that reset the headset, and then I installed the latest firmware and everything works great again, including the backlight.
When I did the update I also unplugged my DP and it went fine. When it got to 98% did you let it sit there for a bit? Mine got to 98% and then it stalled for maybe 10 seconds before the screen flashed and it was complete. I’m sure that support will be able to help you though if you don’t resolve it before they get back in touch with you.
Sorry to hear that. I said disconnect DP because I heard it was advice another forum user gave and I thought it would be an extra safe precaution to unplug it. But yes I left it plugged in. Check out my thread where another forum user resolved it by having Pimax send him firmware that reset the headset.
I got stuck at 98% I did not remove the DP
Then I turn off the PItool and start uploading the DFU again and it works
I think when updating the the firmware the Pitool should be off
Is there no way to get the headset to leave fw mode were it blink blue, red, green? as i stand now windows dont know what I have installed in the USB-port and what ever I try to install drivers for STM Device DFU I fail.
Problem solved! The “Guillemot-thing” was indeed the solution here. After erasing those conflicting files/folders/drivers the update worked like a charm!
