So… its been a while… 1 and 3/4 years.
Straight and to the point, outline is via a … “point”… “system”? (score… cant remember the word)
+1
[Its the Highest res, at the lowest price (still twice the oculus and index… but ok)
+1
The compatibility is equivalent
- 1
"I have little access to modifying the firmware and the SOC. (as of yet)
but XDA are made of rooting GODs
+1
USB C port in the bottom is quite handy. (an inline power source is needed to power any hub tho)(not a big deal)
+0
Customer support… but some of the people are cool, so… + 1
The result is neutral
Overall, with the exception of the bulk (which i could give a shiz)… The headset is adequately engineered for this, best defined as “Superuser”
The only mods I had to make involved the shizzit optical cable i bought, and a double layer of 2 sided velcro to prop up the front just under the eyes.
THE NEAR “DEAL BREAKER”…
-1 I cant find replacement parts
And this is a big one…
If I cannot find parts to fix on this headset (relatively cheap) My next headset will be something i build.
If I have to buy a whole new headset, im getting an HP RV v2. Until i feel like re-soldering anything.
±… not relevant…
But I typed this without taking my headset off.
I didnt know i could touchtype characters
NEAT!
