90Hz native works on my older model 8KX just fine with my 3080 Ti. It works for a lot of people.
But itâs also true that 90Hz does not work in some cases. I donât think we know what percentage of older model 8KX owners that applies to.
You mentioned replacing various parts of your system in an effort to get 90Hz working. Was that at Pimaxâs direction? Did you open a support ticket with them?
Not at all at Pimaxs direction, hahah no I should clarify. Just people here saying its got to be the GPU âworks just fine for meâ, something wrong with my system etc. All thats been changed. I knew Pimax gave up when they responded with intent for me to turn off antivirus after suggesting 3 different firmware+beta pitool combinations, and having purchased the fiber optic cable as well. Its fine though. 75hz all day is fine. And the trade in program nullifies any concerns that Im stuck with a bad unit forever. Again, lower Hz might actually be better for myself. Might sound weird but if the duty cycle of the display could do 45hz without flicker I would probably like that more than 1/2 of 90hz. Also Pimax never advertised 90 hz when I bought it. It was totally an add-on and a surprise, that ended in a bit of futility. There was no false advertising and Pimax did try to help for sure. If they had responded with what serial number do you have? Oh that one doesnât work, sorry, that would have been the best possible response.
Hi,
For me, with 8Kx 2075 model, the 90Hz has never worked (black screen every 3/4 seconds), with an RTX 3090 and a 9900 CPU.
Ticket created, exchanges into forums, nevers succeed to find the root cause
Could we expect this new FW will help to improve 90Hz compatiliby for our âoldâ 8kx headset ?
Sometimes it is extraordinarily difficult to pin down the cause in every case. There are so many different combinations of hardware and software possible that when you push the limits/boundaries there certainly will be cases that arenât solved.
Best we can do is keep at it to solve each case.
That said, our general philosophy is when we find a way to push out improvements in a generally reliable way, even for headsets many years old we have and will continue to press on.
The new 8KX and old 8KX require different firmware which is not compatible with each other because the chips being used, while performing the same function, are different and incompatible and require different code to run. This announcement concerns only the firmware for the new 8KX.
Itâs possible that the same approach that reaches 120Hz on the new 8KX could be applied to the old hardware to improve compatibility for its 90Hz, but this seems unlikely. Itâs probably utilizing capabilities that are only present in the new hardware. In any case, it would require an update to the firmware for the old 8KX to implement it if it was possible.
If youâre talking about trying to run the firmware for the new 8KX on the old 8KX, the headset will not be able to run at all. Donât try this.
If youâre referring to trying the Lindy Repeater in the hope that this will cause 90Hz to work on an old 8KX which is having trouble with 90Hz, that is purely a flail that has been suggested on these forums recently. Thereâs no particular reason to think it will make a difference outside of the specific case (the 3090 Ti) where it has been recommended by Pimax as a workaround.
If using a repeater solved 90Hz issues on the old 8KX, that would almost certainly have already been discovered long before now. The Lindy repeater has been around for a couple of years.
Not necessarily as ppl have been more experimenting to extend the cables with the repeater vs using it more a simple signal booster. If you read the 3090 ti post it was iirc a customer whom tried a repeater with the 3090 ti.
As the 90hz issue seems to also be a potential signal strength issue on some Nvidia RTX gpus the possible solution is worth trying.
Ok, so I just did tried⌠and it fails.
The repeater is âno helpâ, at least for me (8KX 2075, RTX3090, Intel 9900KX).
Still having exact same behavior, without or without it :
Upsaling mode - 110Hz : perfect.
Native mode - 75Hz : perfect
Native mode - 90Hz : flashing blanck or black image every each second
The symptoms for the 3090 Ti issue and the 90Hz issue are different. As I understand it, the former wonât successfully connect at all.
Whereas with the 90Hz issue, itâs clearly connecting and sending frames which display just fine, but it resets every couple of seconds steadily. Thatâs not consistent with signal strength problems. It appears to be receiving signal, but it doesnât seem to be able to keep up with the rate. My impression is that itâs underrunning, resetting, working for a couple of seconds, underrunning, resetting, on and on.
Heyo! so i have a pimax 5k super that I bought with the normal headphones. I bought kdmass headphones for it and the optical cable. can I trade that in for more than the 5k super was worth? since I kinda upgraded it.
Afaik, you just trade in the headset. Like you will literally ship back only the headset, you can sell the other parts on ebay or such and use that towards the 12k. That was my interpretation from reaching out to customer support (I was asking as I had originally sold my SMAS and was wondering if needed to be included when sending back the headset for the trade-in).
I think you meant to ask @PimaxQuorra . However the 5kS is already boosted to $900 value(see pimax website for details) which is higher than msrp. Accessories are not part of the trade in program.
