Upgraded from a 1080ti which worked fine to AMD 6700 xt now whatever I try it always gives me a red light and disconnected plugin HDMI/DP error. Have tried swapping all ports and restarting PC, uninstalling all Pimax software and removing all settings folders nothing works. Has anyone got a AMD 6000 series working here? Thanks
To make things weirder, I can get the headset to turn on with green light but it’s recognised as a secondary monitor and I can see a mouse moving around but still shows disconnected in Pimax!
Thanks, I’ll have a read through. Yes tried both Display ports (other 2 are HDMI) and tried all the USB slots. Opened a ticket anyway, weird cos it works as a normal display except its upside down and flipped in both eyes
Thanks, I tried reinstalling and removing all settings folders and the debug firmware pimax sent me didnt work either. I commented on that thread though thanks for the tip.
Well it was a simple solution after all, just had to disable my Nvidia card in Device Manager. Won’t be able to mine on that card when in VR now that’s all.
