電腦配置:8086+1080ti 16G ram
#6181收到5K+,並改裝。
先說結論,這個轉接環效果還過得去,但是頭殼小的要注意,鎖到最緊還是能讓一隻手掌插入我的後腦位置
不得已只好加毛巾綁上
頭盔的部分,戴的必須比vive還要低才有比較好的甜蜜點,跟大多數人一樣,IPD十分難調整,一眼清楚無比時,另一眼總是有聖光或者不對的焦距,我想這是鏡片的問題
然後把當我在遊玩IL2以及War Thunder的時候,亮度實在太暗(我已調到最亮並且重開)
我的war thunder是不經過steam啟動的,所以超級採樣設定他明顯不經過pitool而是通過steam vr控制,但是pitool的存在卻又卻是影響到了性能(pitool 1 steam 2)
以下我分享一些U11+自動HDR自動對焦的相片(pitool 1 steam 1)
在我这边,是要把Pimax比VIVE戴得高才是甜点,结果是我损失一些上边的图像,还看到了下边的黑框。
论坛上其他网友的反映也是要把头盔往上提一些。
(自动翻译)
Steam VR中的分辨率似乎有最大上限~4096像素宽。 任何更高的值都将被截断为最大分辨率。 如果游戏提供超级采样选项,您可以通过这种方式提高渲染分辨率。
(automatically translated)
Apparently, there is a maximum upper limit to the resolution in Steam VR of ~4096 pixels wide. Any higher values will be truncated to the maximum resolution. If a game offers a super-sampling option, you can increase the rendering resolution that way.
是嗎?早期的超級採樣
200%與400%相比有著確實的差距,可以分辨出兩者的清晰度,我不知道在小派上是否一樣?
是的,您不能依赖于您在Steam VR中看到的分辨率数字。 我不确定200到400之间的差距。我之前没有见过任何提及的人。 当您增加Steam超级采样时,正常和小FOV(视野)将显示更多细节,仅仅因为4096比较小的分辨率。
Yes, you cannot depend on the resolution numbers you see in Steam VR. I’m not sure about the gap between 200 and 400. I have not seen anyone mention that before. Normal and Small FOV (field of view) will show more detail when you increase the Steam super-sampling, simply because 4096 is proportionally larger to their smaller resolution.
Isn’t there a Chinese version of this forum? Wouldn’t it be more effective to post there?
(Note: I am not making any demands. Just wondering.)
Why?
202020202020202020202020
If this is forbidden to speak outside the English language family, I apologize and delete the post
There is no rule as I understand about speaking only English… you shouldn’t need to apologize or delete your post. Though I would have thought Pimax would have a Chinese language version of this forum. I guess not.
I don’t think so, and it doesn’t. The establishment of forums in different regions does not help to Exchange VR information, but I know that the use of the American language family in a mixed language forum is a hidden rule
No it’s not forbidden. Truth if your bilingual in Chinese & english it is also a boon.
From time to time, I’ve seen other languages on this forum.
I visit other forums (duh), so I might be mistaken on 1 or 2 of these, but I think I’ve seen German, French, Spanish, Swedish, Japanese, Korean, and Chinese on this forum. If I’m curious about a particular post, I just use Google Translate.
As I said before, I am not demanding that you make any changes. There is nothing wrong with you posting in Chinese on the forum.
I thought I had heard at some point that there was a Chinese version of the forum. The main advantage of posting there (if it exists) is that the majority of users would speak Chinese and you would have a much larger/more responsive audience.
I thought the same…
I am in China, and frankly speaking except uneducated people(没有教育
) like the author of the post( a7610783) , most young people and computer user can write very good english. ( they have diffuclties to talk but writen is GOOD)
