5k plus multiple crashes when changing refresh rate
I also posted this on the reddit forum and at least one person is having the same issue. When I change the refresh rate on my 5k plus the headset disconnects, and reconnects several times (3-4 usually) then will reconnect with the refresh rate reverted back to 90. It did this before the update as well I just never cared as I wanted it on 90 but now Id like to try 120. Anyone have the same issue or a fix?;
If You’re using an extension cable try without it. Might be because the cable isn’t good enough. I had that happen earlier even with 90Hz (cheap 5m DP extension).
You can also try different DP port if You have two and/or different USB port.
Ive had the same issue. Itbaeems to revert to whatever rate you set for your default.
Hello, Sorry for the very delayed reply. You were right! that seems to fix the issue. Did you ever happen to find a cable that will work with it?
I’m using a DeLock 4K/60Hz 5m cable… :wink:
