3D printed plastic facial interface mod
Person on reddit posted a link to a facial interface mod they made that can be 3D printed (more here: https://www.reddit.com/r/Pimax/comments/b12vcw/pimax_5k8k_facial_interface_for_narrow_faces)
I finally got the 3D printed one piece facial interface mod today. Just tried it out and so far it works great. Really helps with this weird discomfort I was getting with the image on the hmd. It’s about 90% perfect now (still a little blurry in one eye, which makes sense since my left eye monocular ipd is 2mm over compared to my right eye)
The only issues are : I can now see the outside world because there is space by my nose. Can see the side distortions way better (but don’t notice them after 5 mins) and probably lost about 10% of fov (I use normal)
Here’s some pics
This was added to @Davebobman’s table of content wiki. But looks good for narrow faces. Elves are already reporting on it. :beers::sunglasses::+1::sparkles:
That is very awesome :beers:
Hmm I definitely do not have a narrow face, but it works anyways.
This goes to show that pimax really should have shipped 3 face foams with each hmd. BTW I wear glasses and they still work with this mod (and the face foam I got with the pimax)
Or designed the mask to allow dialing distance to lens.
This would be the best bet I think. Works great on the vive
With the mask being removable makes this kind of mod possible. Have some other ideas on how to implement as well.
Nice. I have the problem where I need to space the HMD just a few mm away from my face to get the IPD to my liking or else I get eye strain. I was wondering if you would mind printing and selling me one as I have no printer. PM me or let me know. Thanks!
I have ears for this nice mod too. :wink:
There is a link to thing verse in the Reddit post. You can have them print it.
O ok I see, which company should I choose to print, there are three to choose from, any one you recommend?
I’ve only used print a thing. Make sure you read the description on thingverse it tells use what settings you need. Also I only printed the full face mod not the 2 separate pieces
Awesome… thanks for the info. I ordered the entire set… came to $42.80
You don’t need the entire set. You either need the full one, or the one that is 2 pieces (they made it 2 pieces for people who have 3D printers that can not do the full one)
But it looks as if you don’t need to use the full set either. There are pieces for the top, bottom and sides… and for me I could add options…for example, some people like myself with low IPD need to angle the bottom of the HMD up a little. I could then just use the single bottom piece. In any case, I own more than one Pimax so it gives me either two sets or multiple pieces to experiment with.
ah that sounds like good idea
