39/5000 Will PIMAX 8K work with the GTX 980?
Hello
my configuration:
CPU: i7 3770k
GPU: Gainward GeForce 980 Phantom
Motherboard: GIGABYTE GA-Z77X-UD5H
Ram: 16 GB
OS: WINDOWS 10 64bit
The graphics card has 3 mini DP v.1.2
On the motherboard there is 1 DP port but I do not know what version
Will PIMAX 8K work with my computer?
Regards
I would to be upgrading for sure… 1080 ti
Or just buy 5k version
The 5K doesn’t have any different hardware requirements from the 8K since they both run at the same input resolution
Yeah the primary reason for the 5k really is a cheaper option to the base 8k.
We recommend the 8k hardware requirement:
GPU - GTX980/1070, CPU - i5, Memory - 8GB
The 8k headset has DP 1.4 port, which is compatible with v1.2.
Whether the PIMAX 4K headphones will fit into the PIMAX 8K
